DHCP problem with PEAP authentication
florencethomas
Community Member
We have AP1121G, working with PEAP-GTC authentication.
The authentication proccess is working fine but we are unable to automatically get an IP address from the DHCP server, we have to perform an ipconfig/renew in order to have it.
We try to configure the DHCP server in the AP itself but the problem still the same.
The client is a W2K worstation with SP4.
Is there somebody experiencing the same problem, and who have find a workaround?.
Best regards.
jwmiller
Community Member
Is Broadcast key rotation set to a numeric value other than 0, if so try setting to zero, which effectively turns broadcast key rotation off. We have had problems with broadcast key rotation preventing clients from receiving DHCP assigned IP addresses
