Difference between AIR-AP1832I-E-K9E and AIR-AP1832I-E-K9C ?
dd03nipa12
I have ordered  AIR-AP1832I-E-K9E. I need the Mobility Express functionality.
What is the difference between AIR-AP1832I-E-K9E and AIR-AP1832I-E-K9C ?
Best Regards
Paul Nilsson
Sandeep Choudhary
AIR-AP1832I-E-K9E - Normal Access Point with CAPWAP image, for this you need a controller to make it work.
and AIR-AP1832I-E-K9C -  It comes or need a Mobility express image to work as WLC and AP simultaneously. Also you can connect other APs to it.
Dont forget to rate helpful posts
Sandeep Choudhary
Many Thanks Sandeep ;-)
