Difference between AIR-CAP (A E K) Access Point model
Mahmoudhbm
Frequent Visitor
Frequent Visitor
I am working now a days on Cisco Access Points, as you already know there are different products are available but what i don't understand is each model for example AIR-CAPXXXX-A or AIR-CAPXXXX-E or AIR-CAPXXXX-K
what does A, E, K mean?
Thank you very much for your answer.
Haydn Andrews
The difference between the A E K is the compliance for the region they are being used in.
To find the relevant code for your region use:
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Sandeep Choudhary
Regulatory domain should be same on AP and WLC for the radio network interface to come up.
If you have AP in -A- domain then you must set country code on WLC as USA(America.)
If you have -E- domain on AP then you must set any Europian country on wlc.
and If you have -K- domain on AP then you must set Korea country on wlc.
each country have their own regulation regarding wireless.
Dont forget to rate helpful posts
Haydn Andrews
