Difference between EAP-TLS and PEAP
mchockalingam
Level 4
Level 4
I am looking at various options of WLAN security for our implementation. I came across PEAP. Trying to understand the difference between EAP-TLS and PEAP and not really clear on it.
radiomen
For what I remember EAP-TLS requires certificates in each node, this is difficult to manage. With PEAP you only need a certificate on the authentication server for example a Cisco ACS.
There is more info in the following page thanks.
http://support.microsoft.com/default.aspx?scid=kb;en-us;814394
