Difference Between IW3700 Series IOS Wireless LAN Recovery vs IW3700 Series Controller Based SW Image
Hi everyone
I would to kindly ask what is Difference Between IW3700 Series IOS Wireless LAN Recovery vs IW3700 Series Controller Based SW Image ?
since I want to quote AP IW3702 on CCW but I don't know the difference between those software option?
Please kindly help answer my question
Any suggestion are appreciated
Thank you
RCV is an "interim" firmware.
CAPWAP image is the "full" firmware.
Leo Laohoo
Recovery image, aka RCV, cannot "serve" WiFi.
The sole purpose of the RCV is to hunt down the controller.
Dear Leo
Thank you for you kind answer
so I assume if I want to use IW 3702 as "usual" access point that can serve Wi-Fi I just use the Controller Based image. is it correct?
