Difference in Intel NIC type reported by Device Analytics
talasgair
Frequent Visitor
Frequent Visitor
Hi, I am using 17.15.6 + APSP and have noticed that the hardware model reported for some WiFi NICs is not correct.
E.g. for an Intel BE200 on windows it is reported correctly
C:\>netsh wlan show drivers
Interface name: Wi-Fi
Driver : Intel(R) Wi-Fi 7 BE200 320MHz
Vendor : Intel Corporation
Provider : Intel
Date : 29/07/2026
Version : 24.70.0.3
But on the WLC it is shown as:
# sh device classifier mac-address aaaa.bbbb.cccc detail
Client Mac: aaaa.bbbb.cccc
Device Type: Dell Inc. Dell Pro 14 PC14250
Confidence Level: 40
Day Zero Classification: Dell Inc.
Device Name: Dell Inc. Dell Pro 14 PC14250
Software Version: 24.70.00.03
Device OS: Windows 11
Device Vendor: MSFT 5.0
Power Type: AC Powered
Hardware Model: AX1675/AX211 160MHz
Is this a known limitation?
Mark Elsen
  - @talasgair                   Follow these instructions to enable Network Assurance for the WLAN ; and
                                        then check again :
                                                https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/222643-configure-verify-and-troubleshoot-intel.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi Mark
Thanks for your response. The network assurance is enabled as described in this document. From the debugging, one thing I notice is this error in the RA logs:
[dot11-validate] [22959]: (ERR): Failed to increment the counters for PC analytics, msg id 6 or app_ctxt is NULL
  - @talasgair                    FYI : https://bst.cisco.com/bugsearch/bug/CSCwu42825
                                         Probably not related to the original issue, I consider it as a bug  you could try
                                         more recent releases such as 17.18.5 or 26.2.1 if feasible
  M.
