Differences between 877W versions
760557801535
Community Member
Hi, new here so please be gentle 🙂
Does anyone know what is the difference between the 877W-G-E-K9
(Europe and international version) and 877W-G-A-K9 (America and Asia,
Pacific version) please?
I'm in New Zealand (Asia Pacific region?) and trying to get the
877W-G-E-K9 version working with wireless but having no luck and
wonder if it is a version problem.
Steve
dancampb
Level 11
Level 11
The different code are for which regulatory domain the radios are configured to work in. Each regulatory domain has different channels and maximum power levels that 802.11 can operate at. You should only be using the code that is approved for use in your country.
