Different channels for different SSID's?
tim_buster
Hi all, we have multiple WLANS/SSID's on our controller, which are broadcasting on all AP's.
Is it possible to configure the AP's to broadcast the SSID's on different channels or is this not necessary/usefull.
Do the 2 SSID's interfere?
Thanks in advance!
Tim
Scott Fella
No need... Every radio will be set to a different channel not every ssid. As long as you use non overlapping channels you should be okay. Ex. 2.4ghz use 1,6 or 11
-Scott
Here is a link to another post.
https://supportforums.cisco.com/message/1285308
Two ssids are fine. The more ssids you create, the more beacons in the air. Cisco had a best practice of no more than 4 if possible especially with older devices on the network. It doesn't mean you can't have more.
-Scott
Congrats to your new RED star Scott.
Thanks leolahoo... I didn't even know:)
-Scott
