different VLAN for flex-connect with centralied controller
Sebastian Helmer
Level 10
Level 10
Dear all,
is there an option to define VLANs for the flex-connect SSIDs per location?
Here's my example:
Central WLC --- SSID "WIFI-1" ---  WLC Interface VLAN 99
I want to use on the spoke locations other VLANs than I defined in the Central WLC
Location-1 SSID WIFI-1, VLAN22
Location-2 SSID WIFI-1, VLAN33
......so on..
In the moment I configure it manually and sometimes the VLAN has changed unpredictable, I know there are some BUGs in the code we use, but that was never a big issue 7.4.x . But is there an option where I can decide that spoke location 1 or 2 has to use VLAN 22 or 33 for his flex-connect APs?
I don't see that in ACL or flex-connect group seetings or somewhere.
For me that would be a very useful option for a centralized desing which works very well in our enviroment, we have just a bunch of WLCs per region like Europe, Asia, Amerika...(except one VoIP location)
regards,
Sebastian
0 Replies 0
