differnece between interferences
choda489
Frequent Visitor
Frequent Visitor
hello,
What is the difference between point to point interferences and multi-access interference? Pls, help me
M02@rt37
Hello @choda489,
Multi-access interference, often referred to in the context of Code Division Multiple Access (CDMA) or spread spectrum communication systems, occurs when multiple users transmit data simultaneously over the same frequency band using spreading codes.
On the other hand, Point-to-point interference, also known as co-channel interference or adjacent channel interference, occurs when two or more communication links or devices operating on similar or adjacent frequencies interfere with each other.
Best regards
