Directional antenna for WAP200e
huwyhuwy123
hi there,
Can anyone recommend a directional antenna for the WAP200e.
I've been googling but can't seem to find a product. I have found omni-directional but no directional antennae
Thanks for any help with this.
A
Scott Fella
You just need to find any 2.4ghz patch antenna with a male 'N' type connector.
Just search for that. You can get a coupler to go from rp-tnc to male N type but you will have to add 3db of loss.
http://www.l-com.com/item_mobi.aspx?id=21743
-Scott
Scott Fella
Forgot the link. Here is an example if one
-Scott
