Disable configuring AP over wireless
humphrey.j
Community Member
I have 2 stand alone access points, 1240AG and 1131AG, that I an trying to disable the ability to log into the access points via wireless.  For security, I want to only be able to make settings changed through our wired network.  Does any one know where, either in the GUI or command line, that this setting lives?
Thank you,
Joshua
Surendra BG
Using ACL on any Layer 3 will work!! As such there is no command on the AP to do this job!!
Surendra
Surendra BG
