Disable LED on 2600 AP
carowyzen
Hi everyone,
On IOS 2600 AP, I tried to disable the LED but the command seems to have disappeared. On 1140 running the same 15.2 code, you use the config terminal "led" command but it's not present on the 2600.
Anyone knows why ? or if there is a workaround ?
Caroline
Scott Fella
I thought they removed that option on the 1600's but maybe also on the 2600's. I know you can disable it if the access point was joined to a WLC but maybe they removed the option to do that.
-Scott
