Disable LED on LAP1142N
houdini0112
Hi Guys,
i've got a Problem.
im Working in an Hospital. A few weeks ago we installed an Wireles Infrastructure ( WLC5508 & LAP1142N ). Everything works fine.
Now to the Problem: We installed Accesspoints ( LAP1142N ) in some ratient rooms.
The AP's have an LED on the front. This LED disrupt our Patients so they can't sleep.
Now my Question: is it possible to turn off the LED on an LAP1142N.
All i found on the LAP1142N-E-K9 is the option to flash the LED for a time .
led flash {1-3600 / disable}
On an AP1130AG in our Office i can turn off the LED with this command .
led display off
Does anyone have an Idea how to turn off this LED?
Thank you very much.
Björn
2 Accepted Solutions
Scott Fella
Since it is a LAP, you can do the config ap led-state disable from the wlc cli.
-Scott
If you want to disable only certain AP's, you will need to console into the ap or telent/ssh and run a debug capwap console cli and hit enter.  Then you can do a config t hit enter and enter led display off and hit enter.
-Scott
Scott Fella
-Scott
-Scott
Hi Scott,
Thank you very much. I disabled it on the wlc.
I hope our Patien can sleep tonight.
Björn
Just make sure you enable it on all your wlc's:)
-Scott
