Disable wireless controller POE logs
Guys,
Does anyone know how to disable these Power type/POE trap logs on the wireless controller? I can't see a related checkbox in the SNMP trap controls section.  I have disabled  Auto RF Update traps - TX power update, pretty sure thats related to TPC changes though. Thanks.
Mon Feb 13 10:31:20 2017 AP MAC: xxxxxxxxxxx, AP Name:xxxxxxxxxxx, Power Type/Mode: PoE/Medium Power.
pieterh
I have no answer for the question as you put it.
But what does the corresponding switch report about PoE?
Maybe there is a PoE+ device connected to a PoE "standard" port?
Hi Pieter,
CDP is not enabled on the customers ports, we are using 1830 APs and they are getting 15.4W through ieee . from the datasheet 15.4 is the required amount for the 1830.
Getting tons of those traps in the logs so its just an annoyance more than anything!
