Disabling ssid from broadcasting
Nelson Noia
Frequent Visitor
Frequent Visitor
Can you disable the ssid from broadcasting on a 3750, and if so where on the menu?
bcolvin
Level 6
Level 6
The answer is yes
Here is the reference
http://www.cisco.com/en/US/products/ps6366/products_configuration_guide_chapter09186a00808e6385.html#wp1084813
and as shown in fig 6-3 attached just uncheck the broadcast SSID box. that should do it
Bill
