Disadvantage / Roaming Issues with 2 AP Groups
florian.hanig1
I've a Cisco WLC 2054 with 3 of Aironet 3802 AP's.
I would like to publish 3 SSID's/WLANs(SSID1+2+3) and 1 of the 3 SSID's (SSID 3) should only published on one special AP together with the other SSIDs.
To do this, I create 2 AP Groups:
"AP Group 1" with all SSID's (SSID1+2+3) and only the special 1 AP Member.
And "AP Group 2" with SSID 1+2 (without the "special" SSID 3) and the other two AP's.
Especially with regard to voice wlan...:
Are there any disadvantages when roaming with 2 AP-Groups?
Voice SSID/WLAN is published on all 3 AP's on both AP Groups.
Data Rates are the same on both AP Groups.
Scott Fella
No problem at all. You only have one controller and roaming is fully supported on that. Many do this type of configuration in production.
-Scott
I've now applied that config and have some issues... !
When I go from the first room to the other room with my Macbook or other devies and the client will change to the other AP, the connection drops out...
I've done a client debug for you...
How can I fix this.. ?
(Cisco Controller) >*apfOpenDtlSocket: Aug 13 09:33:43.613: 3c:22:xx:xx:xx:xx Received management frame REASSOCIATION REQUEST  on BSSID 78:72:5d:1e:18:4f destination addr 78:72:5d:1e:18:4f
*spamApTask0: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Received add/del ack packet with sequence number: got 170 expected 170 action = 1
*spamApTask0: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Received ADD_MOBILE ack - Initiating 1x to STA 3c:22:xx:xx:xx:xx (idx 25)
*spamApTask0: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx APF Initiating 1x to STA 3c:22:xx:xx:xx:xx
*spamApTask0: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Sent dot1x auth initiate message for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx dot1xProcessInitiate1XtoMobile to mobile station 3c:22:xx:xx:xx:xx (mscb 4, msg 4)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx reauth_sm state transition 0 ---> 0 for mobile 3c:22:xx:xx:xx:xx at 1x_reauth_sm.c:53
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Normal psk client, full auth
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Created PKC PMK Cache entry for station 3c:22:xx:xx:xx:xx (RSN 2)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Resetting MSCB PMK Cache Entry @index 0 for station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Removing BSSID 70:0f:6a:8d:f8:ce from PMKID cache of station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.620: 3c:22:xx:xx:xx:xx Setting active key cache index 0 ---> 8
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Created PMKID PMK Cache for BSSID 78:72:5d:1e:18:4f  at index 0 for station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: New PMKID: (16)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621:      [0000] 10 57 96 88 6d e9 8c ac e2 6a 1a 79 de 9c eb 50
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Initiating RSN PSK to mobile 3c:22:xx:xx:xx:xxkeyMgmtType : 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx unsetting PmkIdValidatedByAp
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Disable re-auth, use PMK lifetime.
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx dot1x - moving mobile 3c:22:xx:xx:xx:xx into Force Auth state
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Skipping EAP-Success to mobile 3c:22:xx:xx:xx:xx (encryptBit:0)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Found an cache entry for BSSID 78:72:5d:1e:18:4f in PMKID cache at index 0 of station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: M1 - Key Data: (22)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621:      [0000] dd 14 00 0f ac 04 10 57 96 88 6d e9 8c ac e2 6a
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621:      [0016] 1a 79 de 9c eb 50
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Starting key exchange to mobile 3c:22:xx:xx:xx:xx, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Sending EAPOL-Key Message to mobile 3c:22:xx:xx:xx:xx
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Allocating EAP Pkt for retransmission to mobile 3c:22:xx:xx:xx:xx
*spamApTask1: Aug 13 09:33:43.621: 3c:22:xx:xx:xx:xx Received add/del ack packet with sequence number: got 155 expected 155 action = 6
*spamApTask1: Aug 13 09:33:43.622: 3c:22:xx:xx:xx:xx apfUpdateDeleteAckInMscb (apf_api.c:54425) Expiring Mobile!
*dot1xSocketTask: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx validating eapol pkt: key version = 2
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Received EAPOL-Key from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Received EAPOL-key in PTK_START state (message 2) from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Encryption Policy: 4, PTK Key Length: 48
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Successfully computed PTK from PMK!!!
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Received valid MIC in EAPOL Key Message M2!!!!!
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Compare RSN IE in association and EAPOL-M2 frame(rsnie_len :20, and grpMgmtCipherLen:0)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx rsnieCapabilty = c00 rsnie_len =20
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.628: 3c:22:xx:xx:xx:xx Dumping RSNIE received in Association request(len = 22):
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 00000000: 30 14 01 00 00 0f ac 04  01 00 00 0f ac 04 01 00  0...............
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 00000010: 00 0f ac 02 0c 00                                 ......
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 3c:22:xx:xx:xx:xx Dumping RSNIE received in EAPOL M2 (len = 20):
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 00000000: 01 00 00 0f ac 04 01 00  00 0f ac 04 01 00 00 0f  ................
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 00000010: ac 02 0c 00                                       ....
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 3c:22:xx:xx:xx:xx Stopping retransmission timer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 3c:22:xx:xx:xx:xx Sending EAPOL-Key Message to mobile 3c:22:xx:xx:xx:xx
        state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.629: 3c:22:xx:xx:xx:xx Reusing allocated memory for  EAP Pkt for retransmission to mobile 3c:22:xx:xx:xx:xx
*dot1xSocketTask: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx validating eapol pkt: key version = 2
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Received EAPOL-Key from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Stopping retransmission timer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Freeing EAP Retransmit Bufer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx 10.2.9.53 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state 8021X_REQD (3)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent when fabric is disabled:65535
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent :65535 name : client acl id : 65535
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx Vlan while overriding the policy = -1
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx 10.2.9.53 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 78:72:5d:1e:18:40 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx 10.2.9.53 L2AUTHCOMPLETE (4) Change state to RUN (20) last state L2AUTHCOMPLETE (4)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.631: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Reached PLUMBFASTPATH: from line 7157, null
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 78:72:5d:1e:18:40, slot 1, interface = 1, QOS = 1
  IPv4 ACL ID = 255, IPv6 ACL ID = 255,
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Fast Path rule (contd...) 802.1P = 4, DSCP = 34, TokenID = 15206, IntfId = 13  Local Bridging Vlan = 90, Local Bridging intf id = 13
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Fast Path rule (contd...) AVC Ratelimit:  AppID = 0 ,AppAction = 0, AppToken = 15206  AverageRate = 0, BurstRate = 0
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) No 11v BTM
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) NO release MSCB
*Dot1x_NW_MsgTask_2: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx Successfully Plumbed PTK session Keysfor mobile 3c:22:xx:xx:xx:xx
*spamApTask0: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx Add SGT:0 to AP 78:72:5d:1e:18:40
*spamApTask0: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask0: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx Successful transmission of LWAPP Add-Mobile to AP 78:72:5d:1e:18:40
*spamApTask0: Aug 13 09:33:43.632: 3c:22:xx:xx:xx:xx Setting ADD_MOBILE (idx 27,  action 0, last count 170) ack state for STA on AP 78:72:5d:1e:18:40
*pemReceiveTask: Aug 13 09:33:43.633: 3c:22:xx:xx:xx:xx 10.2.9.53 Added NPU entry of type 1, dtlFlags 0x0
*apfReceiveTask: Aug 13 09:33:43.637: 3c:22:xx:xx:xx:xx Recieved MS IPv4 Addr= 10.2.9.53
*apfReceiveTask: Aug 13 09:33:43.637: 3c:22:xx:xx:xx:xx Recieved IPv6 addresses count: 0
*DHCP Socket Task: Aug 13 09:33:43.637: 3c:22:xx:xx:xx:xx DHCP received op BOOTREQUEST (1) (len 312,vlan 99, port 1, encap 0xec03, xid 0xdb342843)
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP processing DHCP REQUEST (3)
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342843 (3677628483), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP   requested ip: 10.2.9.53
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP Opt82 bridge mode insertion enabled, inserts opt82 if opt82 is enabled vlan=90, datalen =18, optlen=68
*DHCP Socket Task: Aug 13 09:33:43.638: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to DS
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 90, port 2, encap 0xec00, xid 0xdb342843)
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP processing DHCP ACK (5)
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342843 (3677628483), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.2.9.53
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:33:43.639: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.5  rcvd server id: 10.2.9.5
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to STA
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 99, port 1, encap 0xec03, xid 0xdb342843)
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP processing DHCP ACK (5)
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342843 (3677628483), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.2.9.53
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.5  rcvd server id: 10.2.9.5
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 90, port 2, encap 0xec00, xid 0xdb342843)
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 10.2.9.1
*DHCP Socket Task: Aug 13 09:33:43.640: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.1  rcvd server id: 10.2.9.1
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 99, port 1, encap 0xec03, xid 0xdb342843)
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP processing DHCP ACK (5)
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342843 (3677628483), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.2.9.53
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 10.2.9.1
*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.1  rcvd server id: 10.2.9.1
and then i go back to the other room:
(Cisco Controller) >*DHCP Socket Task: Aug 13 09:33:43.641: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to STA
*apfOpenDtlSocket: Aug 13 09:34:24.327: 3c:22:xx:xx:xx:xx Received management frame REASSOCIATION REQUEST  on BSSID 70:0f:6a:8d:f8:ce destination addr 70:0f:6a:8d:f8:ce
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Updating 11r vendor IE
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Processing assoc-req station:3c:22:xx:xx:xx:xx AP:70:0f:6a:8d:f8:c0-01 ssid : COMPANY.WLAN thread:1b82ed98
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Station:  3c:22:xx:xx:xx:xx  trying to join WLAN with RSSI -44. Checking for XOR roam conditions on AP:  70:0F:6A:8D:F8:C0  Slot: 1
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Station:  3c:22:xx:xx:xx:xx  is associating to AP  70:0F:6A:8D:F8:C0  which is not XOR roam capable
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Client AVC Roaming context transfer needed? NO
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Setting RTTS enabled to 0
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Reassociation received from mobile on BSSID 70:0f:6a:8d:f8:cf AP SK-Kueche
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Max Client Trap Threshold: 0  cur: 3
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx override for default ap group, marking intgrp NULL
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Applying Interface(we_data) policy on Mobile, role Local. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 90
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Re-applying interface policy for client
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3140)
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3160)
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3181)
*apfMsConnTask_0: Aug 13 09:34:24.328: 3c:22:xx:xx:xx:xx Values before applying NASID - interfacetype:3, ovrd:0, mscb nasid:SUEKI-WLC, interface nasid:, APgrpset:0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Check before Setting the NAS Id to WLAN specific Id 'SUEKI-WLC'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Setting the NAS Id to WLAN specific Id 'SUEKI-WLC'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx In processSsidIE:6947 setting Central switched to TRUE
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx In processSsidIE:6950 apVapId = 2 and Split Acl Id = 65535
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Applying site-specific Local Bridging override for station 3c:22:xx:xx:xx:xx - vapId 1, site 'Kueche_ONLY', interface 'we_data'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Applying Local Bridging Interface Policy for station 3c:22:xx:xx:xx:xx - vlan 90, interface id 13, interface 'we_data', nasId:'SUEKI-WLC'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx override from ap group, removing intf group from mscb
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Applying site-specific override for station 3c:22:xx:xx:xx:xx - vapId 1, site 'Kueche_ONLY', interface 'we_data'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Not applying Local Bridge Policy because Site Specific Interface(we_data) Policy is already applied.
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Applying Interface(we_data) policy on Mobile, role Local. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 90
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Re-applying interface policy for client
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3140)
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3160)
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3181)
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Values before applying NASID - interfacetype:3, ovrd:0, mscb nasid:SUEKI-WLC, interface nasid:, APgrpset:0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Setting the NAS Id to AP group specific Id 'SUEKI-WLC'
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx STA - rates (6): 152 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 13 09:34:24.329: RSNIE in Assoc. Req.: (20)
*apfMsConnTask_0: Aug 13 09:34:24.329:      [0000] 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f
*apfMsConnTask_0: Aug 13 09:34:24.329:      [0016] ac 02 0c 00
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Processing RSN IE type 48, length 20 for mobile 3c:22:xx:xx:xx:xx
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Selected Unicast cipher CCMP128 for client device
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx Received 802.11i PSK key management suite, enabling Authentication
*apfMsConnTask_0: Aug 13 09:34:24.329: 3c:22:xx:xx:xx:xx RSN Capabilities:  12
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx non-11w Capable mobile
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Received RSN IE with 0 PMKIDs from mobile 3c:22:xx:xx:xx:xx
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx the value of url acl preserve flag is 1 for mobile 3c:22:xx:xx:xx:xx (caller pem_api.c:4931)
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Deleted mobile LWAPP rule on AP [78:72:5d:1e:18:40]
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Succesfully freed AID 5, slot 1 on AP 78:72:5d:1e:18:40, #client on this slot 2
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx New ctxOwnerMwarIp:  10.2.99.250 New ctxOwnerApMac:  70:0F:6A:8D:F8:C0 New ctxOwnerApEthMac:  78:72:5D:1D:51:D4 New ctxOwnerApSlotId: 1
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Updated location for station old AP 78:72:5d:1e:18:40 oldSlot 1, new AP 70:0f:6a:8d:f8:c0 newSlot 1, AID 0 MsType 0 MobilityRole 1
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Assigning flex webauth ACL ID :65535 for vlan : 2
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Allocate AID 6 slot 1 on AP SK-Kueche #clients on this slot 4
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx apfMsRunStateDec
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx apfMs1xStateDec
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx the value of url acl preserve flag is 0 for mobile 3c:22:xx:xx:xx:xx (caller pem_api.c:3504)
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 START (0) Initializing policy
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx  apfVapSecurity=0x40004000 L2=16384 SkipWeb=0
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx  AuthenticationRequired = 1
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Encryption policy is set to 0x80000001
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent when fabric is disabled:65535
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent :65535 name : client acl id : 65535
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx Vlan while overriding the policy = -1
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx 10.2.9.53 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 70:0f:6a:8d:f8:c0 vapId 1 apVapId 2 flex-acl-name:
*apfMsConnTask_0: Aug 13 09:34:24.330: 3c:22:xx:xx:xx:xx apfPemAddUser2 (apf_policy.c:438) Changing state for mobile 3c:22:xx:xx:xx:xx on AP 70:0f:6a:8d:f8:c0 from Associated to Associated
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx apfPemAddUser2:session timeout forstation 3c:22:xx:xx:xx:xx - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is  0
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx Sending assoc-resp with status 0 station:3c:22:xx:xx:xx:xx AP:70:0f:6a:8d:f8:c0-01 on apVapId 2
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx VHT Operation IE: width 80/1 ch 52 freq0 58 freq1 0 msc0 0xff msc1 0xff
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx Sending Assoc Response (status: '0') to station on AP SK-Kueche on BSSID 70:0f:6a:8d:f8:ce ApVapId 2 Slot 1, mobility role 1
*apfMsConnTask_0: Aug 13 09:34:24.331: 3c:22:xx:xx:xx:xx apfProcessAssocReq (apf_80211.c:12012) Changing state for mobile 3c:22:xx:xx:xx:xx on AP 70:0f:6a:8d:f8:c0 from Associated to Associated
*pemReceiveTask: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx 10.2.9.53 Removed NPU entry.
*spamApTask0: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Setting DEL_MOBILE (seqno 0, action 6) ack state for STA on AP 78:72:5d:1e:18:40
*spamApTask0: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Setting ADD_MOBILE (idx 27, seqno 172, action 6, count 172, last count 0) ack state for STA on AP 78:72:5d:1e:18:40
*spamApTask0: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Delete Mobile request on slot 1 sent to the AP 78:72:5d:1e:18:40 IP: 10.2.99.247:5272
*spamApTask1: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Add SGT:0 to AP 70:0f:6a:8d:f8:c0
*spamApTask1: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask1: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Successful transmission of LWAPP Add-Mobile to AP 70:0f:6a:8d:f8:c0
*spamApTask1: Aug 13 09:34:24.334: 3c:22:xx:xx:xx:xx Setting ADD_MOBILE (idx 11, seqno 156, action 1, count 156, last count 170) ack state for STA on AP 70:0f:6a:8d:f8:c0
*spamApTask0: Aug 13 09:34:24.337: 3c:22:xx:xx:xx:xx Received add/del ack packet with sequence number: got 172 expected 172 action = 6
*spamApTask0: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx apfUpdateDeleteAckInMscb (apf_api.c:54425) Expiring Mobile!
*spamApTask1: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Received add/del ack packet with sequence number: got 156 expected 156 action = 1
*spamApTask1: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Received ADD_MOBILE ack - Initiating 1x to STA 3c:22:xx:xx:xx:xx (idx 11)
*spamApTask1: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx APF Initiating 1x to STA 3c:22:xx:xx:xx:xx
*spamApTask1: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Sent dot1x auth initiate message for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx dot1xProcessInitiate1XtoMobile to mobile station 3c:22:xx:xx:xx:xx (mscb 5, msg 5)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx reauth_sm state transition 0 ---> 0 for mobile 3c:22:xx:xx:xx:xx at 1x_reauth_sm.c:53
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Normal psk client, full auth
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Created PKC PMK Cache entry for station 3c:22:xx:xx:xx:xx (RSN 2)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Resetting MSCB PMK Cache Entry @index 0 for station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Removing BSSID 78:72:5d:1e:18:4f from PMKID cache of station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Setting active key cache index 0 ---> 8
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Created PMKID PMK Cache for BSSID 70:0f:6a:8d:f8:ce  at index 0 for station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: New PMKID: (16)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338:      [0000] b0 d4 88 f3 e4 40 1c 97 54 c4 7a d2 5e ae e0 08
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Initiating RSN PSK to mobile 3c:22:xx:xx:xx:xxkeyMgmtType : 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx unsetting PmkIdValidatedByAp
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Disable re-auth, use PMK lifetime.
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx dot1x - moving mobile 3c:22:xx:xx:xx:xx into Force Auth state
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx Skipping EAP-Success to mobile 3c:22:xx:xx:xx:xx (encryptBit:0)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.338: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: 3c:22:xx:xx:xx:xx Found an cache entry for BSSID 70:0f:6a:8d:f8:ce in PMKID cache at index 0 of station 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339:      [0000] b0 d4 88 f3 e4 40 1c 97 54 c4 7a d2 5e ae e0 08
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: M1 - Key Data: (22)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339:      [0000] dd 14 00 0f ac 04 b0 d4 88 f3 e4 40 1c 97 54 c4
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339:      [0016] 7a d2 5e ae e0 08
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: 3c:22:xx:xx:xx:xx Starting key exchange to mobile 3c:22:xx:xx:xx:xx, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: 3c:22:xx:xx:xx:xx Sending EAPOL-Key Message to mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.339: 3c:22:xx:xx:xx:xx Allocating EAP Pkt for retransmission to mobile 3c:22:xx:xx:xx:xx
*dot1xSocketTask: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx validating eapol pkt: key version = 2
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Received EAPOL-Key from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Received EAPOL-key in PTK_START state (message 2) from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Encryption Policy: 4, PTK Key Length: 48
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Successfully computed PTK from PMK!!!
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Received valid MIC in EAPOL Key Message M2!!!!!
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Compare RSN IE in association and EAPOL-M2 frame(rsnie_len :20, and grpMgmtCipherLen:0)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx rsnieCapabilty = c00 rsnie_len =20
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Dumping RSNIE received in Association request(len = 22):
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 00000000: 30 14 01 00 00 0f ac 04  01 00 00 0f ac 04 01 00  0...............
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 00000010: 00 0f ac 02 0c 00                                 ......
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Dumping RSNIE received in EAPOL M2 (len = 20):
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 00000000: 01 00 00 0f ac 04 01 00  00 0f ac 04 01 00 00 0f  ................
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 00000010: ac 02 0c 00                                       ....
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.343: 3c:22:xx:xx:xx:xx Stopping retransmission timer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.344: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.344: 3c:22:xx:xx:xx:xx Sending EAPOL-Key Message to mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.344: 3c:22:xx:xx:xx:xx Reusing allocated memory for  EAP Pkt for retransmission to mobile 3c:22:xx:xx:xx:xx
*dot1xSocketTask: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx validating eapol pkt: key version = 2
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Received EAPOL-Key from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Stopping retransmission timer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Freeing EAP Retransmit Bufer for mobile 3c:22:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state 8021X_REQD (3)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent when fabric is disabled:65535
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx flex webauth acl id to be sent :65535 name : client acl id : 65535
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx Vlan while overriding the policy = -1
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 70:0f:6a:8d:f8:c0 vapId 1 apVapId 2 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 L2AUTHCOMPLETE (4) Change state to RUN (20) last state L2AUTHCOMPLETE (4)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Reached PLUMBFASTPATH: from line 7157, null
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Adding Fast Path rule
  on AP 70:0f:6a:8d:f8:c0, slot 1, interface = 1, QOS = 1
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Fast Path rule (contd...) 802.1P = 4, DSCP = 34, TokenID = 15206, IntfId = 13  Local Bridging Vlan = 90, Local Bridging intf id = 13
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Fast Path rule (contd...) AVC Ratelimit:  AppID = 0 ,AppAction = 0, AppToken = 15206  AverageRate = 0, BurstRate = 0
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.346: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) No 11v BTM
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx 10.2.9.53 RUN (20) NO release MSCB
*Dot1x_NW_MsgTask_2: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx Successfully Plumbed PTK session Keysfor mobile 3c:22:xx:xx:xx:xx
*spamApTask1: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx Add SGT:0 to AP 70:0f:6a:8d:f8:c0
*spamApTask1: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask1: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx Successful transmission of LWAPP Add-Mobile to AP 70:0f:6a:8d:f8:c0
*spamApTask1: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx Setting ADD_MOBILE (idx 13,  action 0, last count 156) ack state for STA on AP 70:0f:6a:8d:f8:c0
*pemReceiveTask: Aug 13 09:34:24.347: 3c:22:xx:xx:xx:xx 10.2.9.53 Added NPU entry of type 1, dtlFlags 0x0
*apfReceiveTask: Aug 13 09:34:24.352: 3c:22:xx:xx:xx:xx Recieved MS IPv4 Addr= 10.2.9.53
*apfReceiveTask: Aug 13 09:34:24.352: 3c:22:xx:xx:xx:xx Recieved IPv6 addresses count: 0
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP received op BOOTREQUEST (1) (len 312,vlan 99, port 1, encap 0xec03, xid 0xdb342844)
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP processing DHCP REQUEST (3)
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342844 (3677628484), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP   requested ip: 10.2.9.53
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP Opt82 bridge mode insertion enabled, inserts opt82 if opt82 is enabled vlan=90, datalen =18, optlen=68
*DHCP Socket Task: Aug 13 09:34:24.354: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to DS
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 90, port 2, encap 0xec00, xid 0xdb342844)
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP processing DHCP ACK (5)
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342844 (3677628484), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.2.9.53
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.5  rcvd server id: 10.2.9.5
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to STA
*DHCP Socket Task: Aug 13 09:34:24.356: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 99, port 1, encap 0xec03, xid 0xdb342844)
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   siaddr: 0.0.0.0,  giaddr: 10.2.9.1
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   server id: 10.2.9.1  rcvd server id: 10.2.9.1
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP successfully bridged packet to STA
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP received op BOOTREPLY (2) (len 310,vlan 99, port 1, encap 0xec03, xid 0xdb342844)
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP processing DHCP ACK (5)
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   xid: 0xdb342844 (3677628484), secs: 0, flags: 0
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   chaddr: 3c:22:xx:xx:xx:xx
*DHCP Socket Task: Aug 13 09:34:24.357: 3c:22:xx:xx:xx:xx DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.2.9.53
You should have no issues as long as you are using the same ssid. I bet that even if you place all aps on one ap group you will see the same output. Looks like you might have a feature enabled or a configuration issue on the wlan.
Provide more details like your wlan configuration, what model controller, ap and what code. How many controller and how far apart are the aps when you are testing. Show the roaming on the client by doing a ping to the gateway so we can see if or how many drops. What are you seeing on the client device and are you testing on multiple devices? The more detail, the easier for us to help.
-Scott
