Disconnect wireless when docking computer?
dkweaver1
Community Member
Is there any way to drop the wireless connection automaticlly when a client docks a computer into a wired dock. The wireless radio and wired port are on different VLAN's. I do not want them to be multihomed. I can use different profiles if they bring it up fresh but I am concerned with clients returning from conference rooms to their desks and just docking without rebooting or manually disconnecting. Currently using 1130 a,b,g AP's, WLSE 2.9, ACS Radius servers. Windows XP Pro service pack 1 or 2 (depends on the client)
Thanks in advance!
5 Replies 5
smalkeric
Level 11
Level 11
I think this intelligence has to be built in the OS and none of the OS supports this feature to my knowledge.
I came across this in one of my readings on the net. You can use this utility for windows 2000 and XP.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q311272
The DevCon utility is a command line utility that acts as an alternative to Device Manager. Using DevCon, you can enable, disable, restart, update, remove, and query individual devices or groups of devices.
scottmac
Level 11
Level 11
Many / most laptops keep two profiles: "Docked" and "Undocked" - I believe that if you disabled the wireless adapter in the "docked" profile, then it would be dropped / disabled once the laptop switches profiles.
I don't use a dock anymore, so I can't confirm it, but that's my recollection.
Good Luck
Scott
I believe that Cirond sells a piece of software that does this very thing. www.cirond.com airsafe is the product.
-Karl Lasse
-Karl Lasse
