Display wireless users in PI 3.4 maps
Naz_sys_d
I read about that PI can display users, rogues APs and users, microwave and bluetoosh in PI 3.4 maps, but could not find this option...
Only displayed APs.
Maybe anyone encountered this issue?
Thanks.
2 Accepted Solutions
Rasika Nayanajith
Do you have a MSE integrated with your PI ?
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-4/user/guide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide_chapter_0100111.html
You require that to locate your rogues /interferers
Rasika
*** Pls rate all useful responses ***
Jason Salmans
There should be a filter on the right hand side on the newer maps.  If you scroll down you should see one that says Clients.
I could be wrong but I think you have to have CMX or Mobility Services Engine with the CMX license and it hooked in to the WLC and Prime to get this location tracking.
Rasika Nayanajith
Rasika
Jason Salmans
No, I have not MSE.
I guessed but was not sure, because I did not find it in that part of the documentation and CCNA wireless docs.
Thank you very much.
