03-21-2019 09:39 PM - edited 07-05-2021 10:06 AM
Hello
how i can edit address ip mangament for cisco 1815i controller ME ??
i have addres ip manger : 192.168.0.30 , so i wan to edit other addresss !!??
because i have a pool 19.168.0.0 /24 , so i want to edit other pool and other address ip managment for ME 1815i
what command to edit ???
thanks
Solved! Go to Solution.
03-21-2019 11:56 PM - edited 03-21-2019 11:58 PM
use this command on ME AP:
config interface address management <ip-addr> <ip-netmask> <gateway>
Also make sure you configured the swicthport correctly with allowed vlans.
Dont forget to rate helpful posts
03-22-2019 01:38 AM
is the DHCP pool used for other APs to get IP or for clients ?
My recommandation is:
1. Configure or Change mgmt ip of ME via CLI
2. Once you have access to ME via GUI then you can change the pool.
03-21-2019 09:57 PM
Hi @Dhikra Marghli ,
I suggest you review this discussion of the community:
https://community.cisco.com/t5/wireless-and-mobility/ap-1815i-mobility-express/td-p/3711551
You will find in the answers some help with your doubt.
03-22-2019 01:29 AM
IF i edit pool in the controller 1815i and edit interface ip managment ,
so iif edit pool and ip management with commande CLI not per interface web ,,,???!!
that allow acces per interface web !!
how i can edit pool dhcp and interface web managment per CLI ???
03-22-2019 01:30 AM
03-22-2019 01:38 AM
