Diversity on 4G LTE Network Interface Modules Wireless WAN Interface Cards
I am wondering how one of these NIM's should work if you plug a non MIMO compliant antenna into the diversity input. Will it use both antenna connections or will it only use one?
I have a situation where i have two antenna (in a Cisco 4G-LTE-ANTM-O-3-B) with each connected to either the MAIN or DIV signal inputs. I get no workable signal when plugged one way, but high signal if i swap the cables around. Clearly something is wrong, but I wondered if there was any benefit in fixing the second connection anyway, or should I look at upgrading the antenna to a MIMO one.
Does anyone know?
patoberli
Best thing is, upgrade to a Wi-Fi MIMO antenna.
Also that antenna doesn't support the 5 GHz frequency, so you'd be advised to turn it off on the AP.
