10-08-2021 05:53 PM - edited 10-08-2021 05:57 PM
Hi All,
Going through the SDA-fabric SSID creation on DNA-C (Latest release), I am trying to configure "Guest Access with Sponsored Guest" and the only options available in DNA-C are self-registration and hotspot portals????.
I know self-registration is similar to sponsored but how does this sit within DNA-C regarding provisioning, policies and profiles, is this portal type supported in fabric wireless?
Do I go through the process of creating a self-registration portal on DNA-C, this gets pushed to ISE (3.0) and the 9800 WLC, then configure the portal accordingly for sponsored guest access? Anyone done/tried this?
Cheers,
10-09-2021 02:01 AM
yes as per my understanding the same, DNAC does all work for you.
This document help you :
10-10-2021 02:31 PM
Hi, Balaji,
Thanks for the reply but it doesn't really help, my question was why does DNA-C only give 2 options for guest portals?
Hotspot or self reg????
Cheers,
07-02-2023 12:56 PM
@Jay233 did you get an answer to your question?
