DNA Center and what exactly is Authentication Parameter Mismatch mean?
bill922
Hi, we're running DNA Center and under wireless assurance I see a lot of Authentication Parameter Mismatch errors in our network.  Does anyone know exactly what does this mean?  Is it bad username/passwords?  EAP protocol failure?  Looking for some more details behind this error message?
Here's a screenshot:
In terms of assurance errors I see
Onboarding
Wireless client failed to connect - Security parameter mismatch
Wireless client failed to connect - Security parameter mismatch.
and
Onboarding
Wireless client failed to roam - Security parameter mismatch
No
Wireless client failed to roam - Security parameter mismatch.
So partially trying to determine if this is a connection issue or a roaming issue.
this may be false positive, check on WLC Logs what you see there,
BB
