Do Cisco LWAPPs joined to a Cisco 2504 in local mode run STP on a trunk link back to the switch?
Sam Brynes
Just wondering what I should configure on my switch. If the LWAPP does not run STP, maybe I should enable "spanning-tree portfast trunk" and "spanning-tree portfast bpduguard"?
Scott Fella
You can enable portfast. Take a look at various docs as it shows the basic configuration required.
-Scott
