Do I need a WLC for Client Roaming?
Tim K
Level 2
Level 2
I currently have a Cisco AP running in adhoc mode. I want to expand my coverage in my house, and allow for seamless roaming. Do I need a WLC to do that? Or can I run two APs in adhoc mode and roam between them? If so, are there any specific configurations I need have on the APs to allow it, and what are they?
Leo Laohoo
As long as there is enough signal OVERLAP between the two then it is possible.
Is any additional configuration required for it? Would they have to be on the same channel?
Most definitely not.
