Do SOHO Wireless Routers run routing Protocols?
My Belkin router is running NAT but I couldn't find anywhere where it was routing.
yogeshbb11
Hello josh,
SOHO routers are basically for NAT uses although some of them support RIPv2 and most of them which are less costly routers support only static routing
Thanks & regards,
Yogesh Bhavsar
Spooster IT Services
mohanak
