Does AIR-ANT2506 Ship with A Mast Mounting Kit?
Does the antenna ship with a Mast Mounting Kit or does that have to be ordered separately? If a separate kit is required, what's the part number?
Scott Fella
It comes with one.... take a look at the one that it comes with and see if that will work for you.
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2506.html#wp29525
If you need something different, Sparco Technologies can custom make a mount for you. They also have different type of mounts.
-Scott
