Does AP disconnection trigger RRM DCA?
mhernandez
Frequent Visitor
Frequent Visitor
I got a site (flexconnect, RF group separated) disconnected from the WLC. Just after reassociation, I saw radio reset in all APs from that site.
The question is: what would have caused that radio reset? does an AP association trigger RRM?
thanks in advance!
Leo Laohoo
Depends on the WLC version, model of the AP but it could usually mean a bug has crashed the radio.
Just to add, RRM doesn't reset because one AP crashed.  The algorithm will run every x times depending on what you have set.  Like what @Leo Laohoo mentioned, can be a bug, but you need to open a TAC case so they can help determine the root cause of the crash.
-Scott
