Does dB loss occur enabling UNII-2 channels
thefilmguy
I am trying to refresh my memory here but is there any power loss enabling UNII-2 channels (20Mhz) on 5Ghz with the 3802i access points?
No it doesn’t. The regulatory bodies for countries define the max db for given channels/bands. The only difference you would see is from aps installed in different countries. That doesn’t mean that enabling a uni band and or channels affect other bands.
-Scott
7 Replies 7
Rasika Nayanajith
Refer this file for detailed power & channel setting applicable to each regulatory domain
Rasika
JPavonM
@Rasika Nayanajith excellent reference file. Do you have any information about such file for newest Catalyst 9100 APs? This is very hard to find even using Google advanced search functions.
I'd answer my own question.
These are the reference guides for newest Catalyst APs with power settings and channels per domain:
https://www.cisco.com/c/en/us/support/wireless/catalyst-9100ax-access-points/products-installation-guides-list.html
Jesús
thefilmguy
Thanks but this doesn't actually answer my question. Let me rephrase, does enabling UNII-2 channels have any impact on UNII-1 / 3 existing transmit power?
-Scott
Thank you. I had heard from someone else it would but I think they were confusing the concept that UNII-2 channels have different dB max values. Thanks Scott
You can find the information on many wireless vendor websites. Again, each regulatory body defines what channel and power is allowed for both indoor and outdoor.
-Scott
