Does Fast Roaming supports WPA instead of CCKM ?
p.tavan
The Q&A document about Cisco SWAN says :
"Cisco Central Key Management to help ensure security of client roams"
Does it mean that only CCKM is supported ?
But what about WPA ? Is is supported for Fast Roaming and can I use it instead of CCKM ?
Are other protocols than CCKM supported ?
If you have documents about it, I am interested in.
Thank you,
Patrice
dixho
Level 6
Level 6
Answer: Yes
Answer: Only if you can convenice wi-fi
Answer: I think that there is a protocol proposed by IEEE. I forget the protocol name.
