Does Linksys AE 3000 3X3 MiMO wireless USB client card support 3600 access points which are 4X4 MiMO
banavathkiran
HI all,
Does AE3000 3X3 MIMO Wireless USB client card support Cisco 1262 Access point and 3600 Cisco (4X4 MImo)?
Dual-Band Wireless-N USB Adapter with 3x3 Antenna (AE3000)
• Selectable 3x3 Dual Band 2.4/5Ghz – 450 Mbps
• Cisco Connect Style Setup
• Cradle Base
• WPS (soft) push button and pin support
Cisco 3600 Access point
• 4x4 multiple-input multiple-output (MIMO) with three spatial streams
• Maximal ratio combining (MRC)
  2x3 multiple-input multiple-output (MIMO) with two spatial streams
Thank you in advance
It will work. Many prefer an internal because USB tend to break off:). It will work though.
-Scott
9 Replies 9
Scott Fella
Yes... clients can be a 1,2 or 3 spatial stream and they will still be able to connect.  Doesn't really matter if the client and or AP's have different numbers of transmitter or receivers.  That just tells you what might be the max throughput they will be able to achieve.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I'm still not should on USB and 3 spatial streams. Better to go internal nic if you can ..
George!!!! what the heck does this mean?
Haha
-Scott
Lol .. I need to put Csc down while at the bar ..
I mean I'm not sold on USB with 3 streams. Internal cards are the way to go .. Just my 2 cents ..
Haha!!! You need another drink!
-Scott
Amen to that ! Don't mind if I do ..
Please let me know whether this works fine, because I'm totally confused now, I have chatted with cisco "Live Help Guy" was telling that this USB adpater does not support.
George, I don't have provision for internal wireless NIC card, because the Client is the a Retailer  Machines in airport. which is having only the USB provision.
I have purchase more than 50 numbers for my retailers in airport.
-Scott
If you are using these for pos devices it will work. If you wanted maximize the 3 streams you're better with an internal card..
