Does the AIR-PWRINJ6= power injector protect Access Points from electrical surges?
haziqk
Our customer has several 1852 indoor APs powered by power injectors. Recently a few of them stopped working. Inspection shows that there were burnt marks on the boards near the AP's power supply circuit.
We are wondering what could have happened. Can a lightning surge cause this?
Should the injectors be connected to a UPS?
Do you have any suggestions?
Rich R
We are wondering what could have happened. Can a lightning surge cause this? definitely, yes
Should the injectors be connected to a UPS? Any equipment which needs to be protected should be on UPS unless it is rated to withstand power surges like that (which most equipment is not).
marce1000
               - I have moved this topic to the Wireless group.
  M.
Rich R
Thanks for the feedback, That was helpful.
