dot11 antenna-alignment command
robertc
Community Member
The following command appears in the command reference but doesn't appear in the CLI:
dot11 dot11Radio 0 antenna-alignment
I've tried this command on c1200 AP's with 12.3(2)JA and also a couple of older 12.2 versions. They all respond with Unrecognized command.
dixho
Level 11
Level 11
You can only use the command if the AP is a repeater. The command send probe request frames to all adjacent root APs. Only client station (i.e. not a root AP nor root bridge) can send probe request frames.
