dot11radio is missing
faruk1988
Community Member
            I have a cisco 857w ISR router. My wireless access point was working good until yesterday. Suddenly the wireless light is gone & there is no interface in the router named dot11. I could not even get into the interface configuration mode of dot11radio 0. sh controllers command doesn't show the dot11 interface as well. Is my wireless module is damaged ? Is there any process of recovery ?
7 Replies 7
Leo Laohoo
Possibly.
Try rebooting and post the entire bootup process.
here it goes. The reaload process
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C850 series (Board ID: 2-149) platform with 65536 Kbytes of main memory
Booting flash:/c850-advsecurityk9-mz.124-15.T17.bin
Self decompressing the image : ############################################# [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T17, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 14:40 by prod_rel_team
Image text-base: 0x8002007C, data-base: 0x814E9618
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 857 (MPC8272) processor (revision 0x200) with 59392K/6144K bytes of memory.
Processor board ID FHK11241CFB
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
no ip dhcp use vrf connected
% Invalid input detected at '^' marker.
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
*Mar  1 00:00:04.324: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Mar  1 00:00:04.328: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Mar  1 00:00:07.777: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.773: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:08 UTC Fri Mar 1 2002 to 06:00:08 CST Fri Mar 1 2002, configured from console by console.
*Mar  1 00:00:08.886: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:09.810: %SYS-5-CONFIG_I: Configured from memory by console
*May  9 03:01:09.336: %SYS-5-RESTART: System restarted --
*May  9 03:01:09.340: %SNMP-5-COLDSTART: SNMP agent on host aeolus is undergoing a cold start
*May  9 03:01:09.356: %SSH-5-ENABLED: SSH 1.99 has been enabled
*May  9 03:01:09.432: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*May  9 03:01:09.500: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
*May  9 03:01:09.608: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*May  9 03:01:10.460: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*May  9 03:01:10.872: %LINK-5-CHANGED: Interface NVI0, changed state to administratively down
*May  9 03:01:10.936: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*May  9 03:01:10.968: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*May  9 03:01:10.968: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*May  9 03:01:10.968: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*May  9 03:01:11.944: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to down
*May  9 03:01:11.968: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to up
*May  9 03:01:11.968: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to up
*May  9 03:01:11.968: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*May  9 03:01:12.460: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*May  9 03:01:13.461: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*May  9 03:01:20.502: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*May  9 03:01:21.502: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*May  9 03:01:55.986: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*May  9 03:01:56.986: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
*May  9 03:02:07.025: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*May  9 03:02:07.041: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*May  9 03:02:11.078: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
I can see th BV1 but I don't see the radio.
Could be dead.
Yeah it's dead
-Scott
what to do now ? repairing or replacing ?
Unless you have smart net on that device, there is nothing you can do except get a new wireless router.
-Scott
If you want to get the same model, check e-bay or Cisco Refurbished Equipment.
If you want something better, look for 887W or 897W.
