Dot11radio reset
smartboy2255
Level 3
Level 3
HI all,
I am getting below error in my AP 1231
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset..
Kindly help on this...
Error attached
Thanks in advance
Ajith
Surendra BG
the below logs say htat
SOmeone forcefully shut down the radio interface... however the radio is flapping everytime.. Just make sure if some is toggling around the Radio interface.. if not, then upgrade the IOS to the latest code that we hav if autonomous and if LWAPP based, then also upgrade to latest and if still issue occurs then open up a TAC case with us and we will help you out!!
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
