Downgrade issues
shahinmadambi585
Frequent Visitor
Frequent Visitor
What are the known issues/bugs while downgrading from 17.6.1 to 17.3.5a (9800-40)?
afsalperingodan
Downgrades are not officially supported, and config loss of new features can occur. However, as downgrades can happen in the real world, this document still lists the most common traps to avoid when downgrading.
To find the information you need, check the version you are downgrading from ( the version before the downgrade) from the below documents.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/216838-upgrade-and-downgrade-of-catalyst-9800-c.html#anc33
I hope this helps.
Leo Laohoo
For obvious reasons there will be commands that are not "compatible" with 17.3.X.
afsalperingodan
I hope this helps.
Mark Elsen
 - If you would decide to go ahead you can for instance afterwards use (CLI) show tech wireless and have the output reviewed by : https://cway.cisco.com/tools/WirelessAnalyzer/ , this remains useful when using other procedures too, to have a checkup of the configuration when you are on the targeted version.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
