Drawbacks to using band selection on Cisco wireless controllers
nh6we
Level 2
Level 2
I am looking to enabling band selection on my Cisco wireless controller and was wondering if anyone was aware of any drawbacks or problems in doing so.
Leo Laohoo
I have "Client Band Select" enabled on all of my SSID.  Can't say anything bad.
Leo Laohoo
nh6we
Level 2
Level 2
Along with the question above, is it possible to disable the 2.4ghz radio on just a few access points (not globally).
I've already responded to this question in your other thread HERE.
George Stefanick
I wouldn't do it ... You are better served by just have 2 different SSIDs.
Production = 2.4 Ghz
Production2 = 5 Ghz
Giving clients the option while having the controller trying to steer client to specific bands isn't good. Keep your wireless network simple. Don't add complexity.
