dual authentication with WLC 5508
david.boyer
We're using WLC 5508 controllers, primarily for Windows 7+ clients, and have had success with both certificate and username/password authentication against a Windows Server 2008 R2 radius server. Currently, users can use one authentication method or the other. Is there a mechanism in the 5508 which would require both certificate and username/password authentication rather than just one or the other?
Thanks!
2 Accepted Solutions
Stephen Rodriguez
No, that would be determined by the AAA server, not the WLC.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
ISE should work.  It's all in how you define the connection profile.  There also may be some tweak you need to do on the cleint to make this a 'and' vs an 'or'
HTH,
Steve
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Gotcha, thank you for the reply. Something like Cisco ISE then?
HTH,
Steve
HTH,
Steve
Thank you.
