Dual band 1200 AP, two SSID's?
e.maloney
We have a 1220 AP with the A-band modular card and the b-band mini-pci card. Can you assign each SSID a different name in the same unit? In the setup guide for a dual band AP, they are both called "tsunami" by default. I want each band to be recognised by a different name by my wireless clients. Is this possible?
thanks,
- Ted
derwin
Level 5
Level 5
Hi Ted,
The configuration for the 2 radios is completly separate so you can use either the same or different ssid's and any other radio settings if you use the same you most still configure both radios ie do it twice one on each radio page The best way to think of it as 2 AP's in one chassis
Perfect, that's what I was looking for. I seems to configure that way as well.
Thanks!
- Ted
