Dynamic VLAN Assignment with Web-Auth
baby_yoda
Community Member
I have configured dynamic VLAN assignment on a 5520 WLC using RADIUS authentication with a Microsoft NPS. This works perfectly with Layer 2 802.1x. configured on a WLAN.
Can I configure AAA override to work when using Layer 3 web authentication? I essentially want the WLAN to try for local authentication and then try radius. The authentication works as I would expect but the VLAN does not get assigned. When I think about it being layer 3, I'm assuming the client will already be in the network of the WLAN interface, therefor an ACL would be a better way to handle this?
I am a mere CCNA R&S, so any help would be massively appreciated.
balaji.bandi
Dynamic VLAN assignment does not work for web authentication from a WLC. So you need to find a way ?
ACL - depends on requirement here.
BB
balaji.bandi
BB
Happy with that, I suspected it wouldn't I just wanted to know for sure!
Thanks @balaji.bandi
This could be something to look forward to. On the Catalyst 9800 IOS-XE 17.1 release, VLAN Override on Layer 3 Web Authentication is available.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/config-guide/b_wl_17_11_cg/wlan-security.html#id_109551
