EAP-Fast PAC provisionning problems
o-ziltener
Level 4
Level 4
Hello
perhaps someone could give me an advice for this issue.
I have followwing infrastructure (in the lab):
Windows XP with Cisco a/b/g Card; SW 2.6.0.1, EAP-Fast with AES
AP1121 with 12.3.7JA (WDS-AP)
ACS 3.3.3 (just local user, auto-prov. for the pac)
The Problem: When I boot the PC, Im asked every time by the pc about an expired PAC. If I say yes, the I have to type in user and pw and this fails everytime. Then starts the pc without wireless connection, but after the pc is started, then it is possible to re-authenticate the Pc, and then it works without any new pac provi. perfect. I have tried both autp-pac and manually.
I would like to thank you in advance for helping
Oliver
o-ziltener
Level 4
Level 4
Add info:
There is absoltutely no problems when I change from eap-fast to leap.
No problems during start up.
