10-13-2016 12:53 PM - edited 07-05-2021 05:58 AM
i configure local radius server on ap 1142n, with my anyconnect can't connect with eap-fast.
this my config:
aaa new-model
aaa group server radius rad_group
server name AAP1
aaa authentication login AAP1 group rad_group
dot11 ssid WPAEAP
vlan 15
authentication open eap AAP1
authentication network-eap AAP1
authentication key-management wpa
mbssid guest-mode
radius-server local
no authentication leap
no authentication mac
nas 10.10.110.100 key 7 011A1601431B031D35
user auto1 nthash 7 02245D7E5F205D73151F5B3F5636415B2A217E08700E67667040544F2250707F0A
user auto2 nthash 7 0326022E5229731E17584B234433585C220F7F077C1561714154455A20077F7E01
user auto nthash 7 06555C751816504D5632415E5F277D7E017C116D7645264F5A500F0C0F00715F26
radius server AAP1
address ipv4 10.10.110.100 auth-port 1812 acct-port 1813
key 7 151B1B091C3A2E363C
The output of show radius local-server station show:
unknonw usernames 245 !!!!
help me please.
versione 15.3.3 JC
10-13-2016 04:24 PM
I think it is an issue with the software versions of your AP & compatibility with AnyConnect.
I am sure this will work if you downgrade your AP to a code like this (c1140-k9w7-tar.124-25d.JA.tar). Below is my reference configs
https://mrncciew.com/2013/04/28/wgb-with-eap-fast/
Rasika
*** Pls rate all useful responses ***
10-14-2016 12:26 AM
hi,
what is your anyconnect version ??
please help me ..i'm crazy for this...work with external radius....
10-14-2016 10:42 AM
I am using Anyconnect 4.2.04039
It is not the AnyConnect version, but AP IOS version. If you use 12.x you can see it is working even AP using as local radius.
Rasika
10-15-2016 03:01 AM
In my opinion the proble is on anyconnect..not the release..
in the debug log seem that anonymous cliet try access... but ti use this is wrong...
i use the latest version of any connect 4.3.... uff
10-15-2016 11:26 PM
Excuse me rasika, where did you found this incompatibility issue..????
10-16-2016 11:53 AM
I tested this myself with different version of AP IOS image. with 15.x I could not get it working with AnyConnect, but works well with 12.x code
Rasika
10-25-2016 05:15 AM
boo
i will try...
