EAP-PEAP - client certificate required
wleppens82
Frequent Visitor
Frequent Visitor
I am deploying a wireless network. Clients are connecting to the network using dot1.x eap-peap authentication.
We are using windows IAS and with a local CA configured on the same machine.
Clients are able to connect properly.
Is there a way to avoid that clients that do not validate the server certificate can be denied from accessing the WLAN?
Regards, wim
George Stefanick
The short answer is no. Bummer, I know. This is a function of the wireless client / supplicant. What you could do is set it to check cert and lock the supplicant so it cant be changed by the end user, of course depending on your supplicant ...
