EAP-TLS machine authentication problems
kjae
Community Member
Well..
I have the following devices:
WCS
Wlan controller 4402
AP 1130 LWAPP
Workstation XP sp2
Secure ACS 4.0
Windows CA
Windows AD
Everything else is working properly, except EAP-TLS. Server certificate is installed in ACS and trust list is OK. Client certificate is installed in workstation machine store. PEAP-MsCHAPv2 working OK, ACS logging prompts successful authentication. I tried to use the certificate authentication from windows wlan properties, but the log was still empty.
Which clarifications do I have to do in ACS and AD?
Can someone help me and give me very detailed instructions on how to make it work.
satukoivikko
Community Member
We had a same problem until we ran 2 windows hotfixs. Those are: WindowsXP-KB893357-v2-x86-ENU.exe and WindowsXP-KB890046-x86-ENU.exe Have you tried to do this. Our EAP-TLS machine authentication is working fine now.
Have you enabled EAP-TLS authentication in ACS? ACS-> System configuration: Mark Allow EAP-TLS
