EAP-TLS not working
ruben.montes
Level 4
Level 4
I have deployed PEAP working well, but not able to make EAP-TLS work. I've followed the deployment guide from Cisco. I can't see anything in the ACS log, and with a debug radius in the AP i can only see a loop sending Access-request and Access-Challenge all the time. I can't see the exchange of certificates between the ACS and the supplicant. I have XP SP2 installed, maybe a problem with SP2?
Should I issue the certificate of the client to the same person who is actually logged in the machine? Should I put a domain in the supplicant?
I'm using ACS database authentication.
If you need more info please let me know.
Ruben
0 Replies 0
