EAP-TLS stability issue
litouch
Level 2
Level 2
I have a company-wide EAP-TLS 802.1X network. Sometimes some end users can't connect to this EAP ssid, and always go the "guest" one. Sometimes some end users can't get dynamic IP.
On the ACS server, I sniffered, and I even saw the "radius accept" packet, but no accounting packet followed. There are many "challenge -> accept -> challenge -> accept" circle.
I checked the syslog error "Deauthenticating Station xxxxxxx Reason: Sending station has left the BSS ", and tried to change the signal channel, and also I removed one helper IP from the L3 switch vlan interface.
These seem to do some work. But I still not very sure.
Does anyone suffer this issue?
Thanks.
Ed
sadbulali
Level 8
Level 8
This occurs due to interference from adjacent access point. Adjust the power and channel settings on the access points. Also try upgrading the Client adapters.
Thanks for the thread. hmm, signal, channel...
Ed
