EAP-TLS With AD configuration issue
amin
I am using Aironet Wireless Client Adopter running on Win XP and Win2K machine. The WLAN Clients are connecting to Cisco 1200 APs which uses Radius (ACS 3.2) Authentication through MicroSoft Active Directory user Database(installed on Win2K Advance Server). The certificates are issued to ACS and all WLAN clients from local CA (installed on win2k advance server). The configuration is done exactly given in EAP-TLS DEPLOYMENT GUIDE FOR WLAN.
Problem is, the wlan clients do not authenticate through EAP-TLS process. All the servers like ACS, CA and wlan clients are logged on to the domain. I can see the log message on AP i.e.
EAP-TLS or PEAP authentication failed during SSL handshake.
I am sure there is some thing wrong with the certificate, either at client side or server side (ACS or AD).
Can any body faced this problem before or help me in dig more into this?
Amin
dixho
Level 6
Level 6
Is the CA in the trusted list on the ACS and wireless clients? Please do a MMC on windows to find out.
Yes, i can see the CA in the trusted list...
Amin
