Effect changing switch VLAN ID on switch access port on standlaone access point
buro_1986
I need some guidance on wireless. I am working on a customer where the there are many standalone access points. Currently the customer is running only VLAN 1 in its network. Now they want to move to remove VLAN 1. I am going to change vlan ID from 1 to 111. I am in doubt whether ap will work or not with this change.
Do i need to make any change on AP regarding the native VLAN. Current configuration on AP is as below:-
interface BVI1
ip address 10.76.49.49 255.255.240.0
no ip redirects
bridge irb
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
encryption key 1 size 128bit 7
encryption key 2 size 128bit 7
encryption key 3 size 128bit 7
encryption key 4 size 128bit 7
encryption mode wep mandatory
ssid WLANIndust_2010
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
dot11 ssid WLANIndust_2010
authentication open mac-address mac_methods
infrastructure-ssid optional
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
duplex auto
speed auto
bridge-group 1
Seb Rupik
Hi there,
Your AP is not configured to send or receive tagged frames on Fa0/0, it will be totally oblivious to you changing the VLAN ID on the switch it is connected to.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
