Enable Flex Connect mode in WLC
Raj_82
We have two branch offices and the WAN is connected through IPsec tunnel. Presently those two office has Couple of AP's and it is connected to DC WLC in local- Centralize switching mode.
Now we are planning to enable Flex Connect mode to branch office AP's.
Single SSID is used for corporate user. IN order to enable Flex conenct local switching mode in the SSID , will it cause any issue excising wireless users those using this SSID. Or we need to create separate SSID ?
8 Replies 8
Central switching but what about l2 secuirty are it done in wlc?
You need also to be sure that ap can forward clinet traffic, config svi in sw , config dhcp for client.
 Flexconnect mode implies a lot of changing. And Yes, it will impact currenltly clients. At least, build up a new temporary ssid as a midle step to the final scenario
 You need to think about how they will get IP address, how they will authenticate and the path they will take with this new topology.
 A lot to think through. In local mode mode, communication start from wlc and the capwap tunnel work as an overlay topology and abstract many step for you.
 Leaving the traffic locally,  can uncover many challenges.
Raj_82
Yes L2 security is configured in WLC
Presently the AP is connected  to "Switchport mode access ". We will configure the port into Trunk mode while enabling the flex connect.
Can we enable flexconnect local switching for existing SSID or do we need create new one?
Raj_82
Thank you for the answers. I will setup one SSID for testing and let you know outcome.
ammahend
can you answer why you made this decision ?
-hope this helps-
We’ve got complains from users disconnection from the wireless network from branch office, and I’ve noticed that there’re quite a fair bit of disassociations from the APs.
I have attached the logs
Please suggest if  any other option available to fix this issue without changing flex connect
Thank you.
                               >....Please suggest if  any other option available to fix this issue without changing flex connect
 - Look into . https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html   , advised to execute first . check if that can help.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
You can verify these resets against this link.
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-3700-series/117869-technote-ap-00.html#anc2
most of them are 62 “Radio channel set. Reset while setting channel from Control and Provisioning of Wireless Access Points (CAPWAP)” by changing to flexconnect, you are only shifting the data plane to AP locally your control place remains at controller, which these messages are complaining about so moving to flexconnect will not necessarily  solve your problem specially if your resources and internet are central . I think You have to investigate more on the link (IPsec, may be it’s timeout or MTU issue, just saying)  or use one of the AP as mobility express and keep control plane also local to the site as well, since there are only few APs there.
hope this helps
-hope this helps-
