Enabling Monitor Mode for Slot0 on Cisco AP 3802 using WLC9800
sharpshooter94
Hello All,
I am trying to configure monitor mode for the Slot0 only on Cisco AP 3802. But it seems there is no command to do this. I am using C9800-CL-K9_IOSXE, Version 17.12.3
Appreciate some help and advice on this.
Thank you !
marce1000
    - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/monitor-mode.html#enable-monitor-mode
  M.
Thanks for your reply. However, I already saw the link previously and that command is to enable the monitor mode for the whole AP (slot 0 and slot 1). However, my goal is to only enable slot0 for the monitoring mode for the 3802 APs, while slot1 will still be using for 5Ghz client serving.
Saikat Nandy
Please try -
WLC#ap name <ap name> dot11 dual-band shutdown
WLC#ap name <ap name> dot11 dual-band radio role manual monitor
WLC#ap name <ap name> no dot11 dual-band shutdown
